FARO Zone 3D FARO Zone 3D - 2018 FARO Zone 3D - 2019 FARO Zone 3D - 2020 FARO Zone 3D - 2021 FARO Zone 3D - 2022 FARO Zone 3D - 2023
7.x
6.x
5.x
4.x
LT
Capture and Process
SmartInspect
Measure Q
As-Built
AutoCAD
Revit
Modeler
VirtuSurv
VirtuSurv 2019
VirtuSurv 2018
FARO Zone 3D
2022
FARO Zone 2D
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Visual Inspect
CAD Translator
Legacy Software
CAM2 Gage
Error-SafeNet Code19 Unable to Apply V2C File HASP_INV_UPDATE_DATA
Probable causes with solution for Error 19 could be:
-> C2V or V2C file is downloaded via OWA (Outlook Web Access). The file may become blank, and the size of the file changes to 0 KB or much less than the actual file size. If you put the C2V or V2C file in a folder and zip it, then the file remains intact. The update may fail with Error 19 (HASP_INV_UPDATE_DATA) if the V2C is downloaded via OWA.
-> Error: "Unable to apply V2C file"/"HSP_INV_UPDATE_DATA"/”Requested XML Tags not found":
Open the V2C file in Notepad to verify if correct XML tags are listed. Sometimes e-mail might change the '<' to the HTML tag version of it, '&lt'.
If you have any problems, contact customer service.
