CAM2 CAM2 - 2021
2022
7.x
6.x
5.x
4.x
LT
Capture and Process
SmartInspect
Measure Q
As-Built
AutoCAD
Revit
Modeler
VirtuSurv
VirtuSurv 2019
VirtuSurv 2018
FARO Zone 3D
2022
FARO Zone 2D
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Visual Inspect
CAD Translator
Legacy Software
CAM2 Gage
TCP/UDP Port Used by the Sentinel HASP Driver and FARO Licensing System
Install Icon
Local HASP Driver Port
FARO uses SafeNet/Gemalto, Sentinel HASP, to provide product license keys for all FARO software, whether you use a dongle/portlock or a product license key that you type into the FARO software. The Sentinel HASP driver uses communications port 1947 on your computer. Make sure applications other than Sentinel HASP and firewalls do not block this port.
Port 1947 is registered with the Internet Assigned Numbers Authority (IANA) by Aladdin/SafeNet/Gemalto. If other applications are running on this port, they may prevent the licensing and use of FARO software. To correct this problem, contact your IT department and ask them to reassign the communications port for applications other than Sentinel HASP and allow port 1947 to be accessed.
License Activation and Update Port
The FARO licensing system uses port 6780 at the following URL/IP addresses:
http://license.faro.com:6780
and
http://13.69.27.89:6780
The connection is not encrypted.
If you are having issues activating or updating a software license, ensure all hardware and software firewalls are allowing traffic on port 6780 and the above domain/IP addresses are not blocked.
IPv6 Notes
The FARO licensing system uses IPv4 only. A translation of the FARO licensing system endpoint IPv4 address into IPv6 CIDR subnet is provided here:
0:0:0:0:0:ffff:d45:1b59/128
or, in extended format:
0000:0000:0000:0000:0000:ffff:0d45:1b59/128
See Also
Keywords
COM settings, ports, conflicting communications ports, conflicting ports, port conflicts, HASP error message, licensing error message, installation error message
