SCENE SCENE - 2019
7.x
6.x
5.x
4.x
LT
Capture and Process
SmartInspect
Measure Q
As-Built
AutoCAD
Revit
VirtuSurv
VirtuSurv 2018
FARO Zone
2D
FARO Zone 3D
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Visual Inspect
CAD Translator
Legacy Software
CAM2 Gage
Troubleshoot Network Connections
Install Icon
If the client computers cannot receive a license from the server, try these steps.
Details
  1. Open the Command Prompt by typing the cmd into the Windows search bar.
  2. Use the ping command and input the server IP address
    If you receive all replies successfully continue to step 3.
    If not then there are network communication issues occurring. It may be that the network firewall is preventing port communications between the two computers. Please contact your network administrator to create a port exception for port 1947.
  3. In Command Prompt type netstat -aon | more.
    This provides a list of ports and their current state.
  4. Locate the local address 0.0.0.0:1947 and take note of the PID that is listed.
  5. Open task manager by right clicking on the task bar or pressing Alt+Cntrl+Del. Go to the Services tab and sort by PID. The PID that was listed under local address 0.0.0.0:1947 should be named hasplms and this should be true on both the client and server computers.
See Also
Keywords
HASP error code, problem code, XML header not found, XML header changed, manually update license key
