Scan in a Box Scan in a Box - M Scan in a Box - S
3D Imager
Cobalt
Rotary Table Driver for Cobalt 3D Imager for Array Configuration
Cobalt Imager Icon
Currently, the Cobalt 3D Imager interface does not support the rotary table when using multiple in an array configuration.
BuildIT offers an automated process that supports the use of using an array in combination with the rotary table. If using this setup, the table needs to be connected to the computer through a USB connection, and the drivers for the table need to be installed separately.
Please follow one of the two procedures below that pertain to your situation.
Quick Steps
If using a Rotary Table with an Array Configuration, please perform the following procedure:
  1. Download the driver below.
    Download
  2. Run “Arcus Drivers and Tools Setup 1.43.exe”.
  3. Once the driver is installed, navigate to Run on your PC.
  4. Input the following:
    C:\Program Files (x86)\Arcus Technology\Drivers, Libraries, Source\PerformaxUSB v4.01\PerformaxUSBInstaller_x64.exe
  5. Click OK.
Note: This procedure is only required if you are using a rotary table with an array, as the array doesn’t support rotary table automatically.
If using a Rotary Table with a single Cobalt, it is recommended:
  • Plug the rotary table into the single Cobalt and use the Cobalt user interface to control the table instead.
  • You do not require the driver.
