Cleaning Guidelines for the Mirror on the Focus3D Laser Scanner
Only use cleaning fluid WITHOUT alcohol or acetone to clean the optics on the Focus 3D. FARO recommend alcohol-free lens cleaner that can be found in most optical supply stores.
Detailed instructions to clean the mirror of the Focus 3D are in the Maintenance section of the manual which can be downloaded from the following link here:
Keywords: clean, liquid, mirror, alcohol, acetone, cleaning, optic, optics, Focus 3D cleaning
