Delete or Format the SD Card Used with the Focus3D Laser Scanner
You can erase or reformat the Focus3D SD memory card. All the file folders required for operation are correctly populated the next time the memory card it is used in the Focus3D.
See Also
- Memory Cards Used With the FARO Laser Scanner and Formatting Instructions
- Data Recovery Options and Usage Guidelines for the SD Card Used with the Focus3D Laser Scanner
- Error-Scanning Is Not Possible without SD Card. Please Insert an SD Card into the Scanner on the Focus3D
- Error Codes for the Focus3D
setup, SD card, ls, laser scanner, memory, re-image
