Error-Code 1440 for the Focus3D Laser Scanner
On the FARO® Laser Scanner Focus and Focus3D, error number 1440 means there is an internal operational failure of some nature. This could be caused by a variety of internal errors.
Quick Steps
Before contacting FARO support, the following should be considered and checked:
- Check if your firmware is up to date. A firmware update can often resolve most issues. Refer to your respective model's latest firmware update below.
- Have you tried a factory reset? Click here for a quick step-by-step.
- Have you been using your equipment in a valid temperature range? Refer to your respective model's tech sheet below.
If you're working in extreme hot conditions, consider the thermal protection cover.
If you've exhausted all three of these solutions, then please contact FARO support.
