Power Block Battery (ACCS-PWR-0014) for the Focus and Freestyle 2
A new FARO® Power Block battery, p/n ACCS-PWR-0014 is now available as a direct replacement for the older ACCSS8001 battery. This new battery features redesigned battery controller circuitry and increased capacity from 92.2Wh to 97.9Wh providing improved performance and robust battery life.
- The ACCS-PWR-0014 battery is compatible with the FocusM and FocusS Laser Scanners*, Freestyle 2 Mobile PC, and Power Dock Chargers (ACCSS8002 & ACCS-PWR-0013).
- The ACCS-PWR-0014 battery is required for Focus Premium models, the older ACCSS8001 battery will not power the unit.
*Important note to FocusM and FocusS Laser Scanner users:
Use of the ACCS-PWR-0014 Power Block battery is not supported by Focus firmware versions 6.5 or 6.6. Scanners using these versions must be updated to version 6.7 or greater.
