Thermal Cover and Status Indicator Manual for the Focus Laser Scanner
Quick Steps
Click the link in this table to download the latest FARO® Focus Thermal Protection Cover and Status Indicator Manual.
Date | Download |
Jun 2019 |
Thermal Cover
The thermal protection cover keeps the Focus from overheating in hot environments or in strong direct sunlight. It is effective for high atmospheric temperatures up to +55° C or +131° F. For operation within standard temperatures, +5° C to + 40° C, or +41° F to +104° F, you should not need to use the thermal cover. But for operation above 40° C, or 104° F, or in strong direct sunlight, we recommend using thermal protection covers to protect the Focus against the effects of excessive heat and to extend its operation time.
During continuous operation in extreme heat, the Focus gradually warms up even when you use thermal protection covers pre-cooled to 10°C or 50°F. Tests at extreme temperatures and in direct sun indicate that using a single set of pre-cooled thermal protection covers extends the operation time by at least two hours. For scanning sessions in extreme heat that extent beyond two hours, use two sets of thermal protection covers. Replace the first set after 45 minutes, and continue the scanning session with the second set.
To order thermal production covers, contact your regional FARO Sales Representative.
Status Indicator
The status indicator enables you to see the scanner’s LED colors and blink codes from more positions and from a greater distance. The light of the indicator is visible from all sides of the scanner except the side with the touch screen and can function no matter the orientation of the scanner.
The status indicator is suitable for indoor/or outdoor use, but it is NOT waterproof and should NOT be used in the rain or an environment where it could get wet.
See Also
- Spark-Proof, Explosion-Proof, and Intrinsically Safe
- Environmental Specifications and Overheating Prevention of the Focus3D Laser Scanner
- Technical Specification Sheet for the Focus M70 and S70/S150/S350
- User Manual for the Focus M70 and S70/S150/S350
laser scanner accessories, ls, heat protection cover, over heating, temperature control, shade, ambient temperature, heat, celsius, temp, fahrenheit, environmental conditions, heat shied, cold pack
