FARO Zone 3D FARO Zone 3D - 2018 FARO Zone 3D - 2019 FARO Zone 3D - 2020 FARO Zone 3D - 2021 FARO Zone 3D - 2022
Battery Safety and Compatibility for the Freestyle2
Battery Compatibility
Use only FARO® Power Block batteries, other batteries are not supported.
NOTE: Older versions of the Power Block battery are not compatible with the Mobile PC and Freestyle 2. Ensure that your Power Block battery label includes the designation "HC".
  • Spare Power Block Battery: ACCS-PWR-0014 (replaces ACCSS8001)
  • Power Dock Battery Charger: ACCS-PWR-0013 (replaces ACCSS8002)
  • Power Supply for Power Dock Charger: ACCSS8006
For charging/LED status information, see: Status LEDs for the Freestyle2 and Mobile PC
Battery Safety
The following safety measures must be followed when working with the Power Block battery:
  • Charge the Power Block only in the Mobile PC or in a charger recommended by FARO to charge the Power Block.
  • Do not charge or discharge damaged batteries.
  • Do not charge the Power Block in the mobile PC when it is stored in the transport case.
  • Do not use wet or dirty batteries in the FARO Laser Scanner or with the charger.
  • Charge within limits of 0 °C (32 °F) and 45 °C (113 °F) temperature. Recommended charging temperatures: 10 °C (50 °F) to 30 °C (86 °F).
  • Discharge within limits of -20 °C (-4 °F) and 60 °C (140 °F) temperature. Recommended operating temperatures: 5 °C (41 °F) to 40 °C (104 °F).
  • Insert or remove batteries in dry and dust-free environments only.
  • When the mobile PC is not in use for a longer period of time, remove the Power Block.
  • Store the Power Block only when it is charged (at least 60% charge state). It is recommended to charge the Power Block once a year when it is stored long term.
  • Storage temperatures: -20 °C (-4 °F) to 45 °C (113 °F), storage humidity range: 0% to 80%. Store in a well-ventilated area. Do not store with metal objects. A short circuit can cause a fire.
  • Do not bring metal objects into contact with the batteries' terminals. The terminals may short circuit and generate heat in this condition.
  • Do not immerse batteries into water or fire (danger of explosion).
  • Dispose of batteries in accordance with environmental regulations. Contact your local waste disposal management authority for guidelines concerning lithium ion batteries.
Transport
  • The FARO batteries are lithium-ion batteries and are thus classified as dangerous goods. When transporting or shipping the FARO batteries, ensure that you observe all applicable local and international rules and regulations. For further information, contact your local forwarder before transportation or shipping.
  • For lithium-ion batteries with less than 100 Wh energy content, an exemption is provided that allows you to carry such a battery without further paperwork. The maximum battery energy a single person can carry is 200 Wh.
