Freestyle 2
Scanning Best Practices with the Freestyle2
Tips for Successful Scanning
Scanning with Freestyle 2 is easy, but there are some guidelines which will help you get the best results.
  • Plan how you will scan the objects of interest before you begin, taking the following recommendations into consideration:
  • The longer a single scan takes, the longer the processing time will be. Try to keep scan times as short as possible—under 5 minutes is best.
  • It is better to have one scan that captures all objects of interest than to have several scans. Fewer scans means less registration.
  • Move the handset slowly and constantly, avoid jerky movements. Fast and jerky movements may lead to inaccurate data or tracking may be lost.
  • Accuracy and tracking may be improved if you avoid excessive twisting movements while scanning:
  • Make sure that the objects of interest are within the specified maximum range and minimum range of the handset.
  • Objects or surfaces may have an increased noise or reduced data if they are directly illuminated by bright sunshine.
  • Use markers for high accuracy tasks
  • If the number of features is low or badly distributed, try to move the handset's field of view to areas with more structures.
  • Scanning areas with few features or without texture can be difficult. Add markers or other artificial targets for better results.
  • If the lighting conditions are bad, use the flashlight to get better results.
  • If you are not able to scan dark areas, treat these with developer spray.
  • If you are not able to scan shiny areas, treat these with anti-glare spray.
  • Try to move the handset in circles or loops. This helps with loop-closing.
  • When scanning all sides of an object, start and stop at “less interesting” positions. For example, when scanning a person, start and stop at the back.
  • Try to finish a scan at the place where you began. This helps with loop-closing.
  • Objects must not move while they are captured.
Avoid:
  • Scanning your shadow while making outdoor scans
  • Having only plain-colored surfaces (e.g., a white wall) in the handset’s field of view
  • Having only shiny surfaces in the handset’s field of view, example metal rails, or high-gloss lacquer
  • Having only highly absorbing surfaces in the field of view, for example black furniture
  • Scanning when the temperature is lower than 0 °C or higher than 40 °C
  • High concentrations of dust, fog, rain or snowfall. This may result in bad measurements. Avoid scanning under these conditions.
