SmartPhone Compatibility with the Freestyle2
You control the FARO® Freestyle 2 via an app on a Android smartphone. FARO recommends the use of the Samsung A71, which can be purchased directly from FARO (part# ACCSS8039). You may may use your own smartphone, provided it meets or exceeds the specs of the Samsung A71. A list of devices that have been tested and verified to work with the Freestyle 2 is also provided below.
Chipset | Qualcomm SDM730 (8nm) or better |
Processor | Octa core |
OS | Android 10 |
RAM Memory | 6 GB |
Screen Size | No minimum requirements, recommend at least 5.5 Inches |
Supported Smartphones
The following list of smartphones have been tested and verified to work with the Freestyle 2.
(Updated September 25th, 2020)
Name | Model number | Phone firmware | Date of approval |
Samsung Galaxy S20 FE | SM-G780F/DS | Android version: 10 Kernel version: 4.19.87-19871399 Build number: QP1A.190711.020.G780FXXU1ATJ5 Android security: October 1st 2020 |
11.12.2020 |
Samsung A71 | SM-A715F | Android version: 10 Kernel version: 4.14.117-18912382 Build number: QP1A.190711.020.A715FXXU3ATH8 Android security patch level: 1 August 2020 |
24.09.2020 |
Samsung S10e | SM-G970F | Android version: 10 Kernel version: 4.14.113-19530501 Build number: QP1A.190711.020.G970FXXU8DTH7 Android security patch level: 1 September 2020 |
24.09.2020 |
Samsung S10e | US version | Android version: 10 Kernel version: 4.14.117-18725736 Build number: QP1A.190711.020.G970U1UES4DTH3 Android security patch level: September 1, 2020 |
28.09.2020 |
Sasmung S10 lite | SM-G770F | Android version: 10 Kernel version: 4.14.117-19556629 Build number: QP1A.190711.020.G770FXXU3CTH4 Android security patch level: 1 September 2020 |
25.09.2020 |
Fujitsu Arrows BZ-01 | BZ01 | Android version: 9 Kernel version: 4.9.112+ #1 Fri Sep 27 20:15:58JST2019 Build number: V01RB33B Android security patch level: 1 September 2019 |
09.09.2020 |
Former Versions:
Samsung S10e | N/A | Android Version : 10 Kernel Version : 4.14.117-18725736 Build Number : QP1A.190711.020.G970U1UEU4DTF3 Android Security Patch : July 1, 2020 |
28.09.2020 |
Samsung S10e | N/A | Android version: 10 Kernel version: 4.14.117-18725736 Build number: QP1A. 190711.020.G9701UES4DTG1 Android security patch level: August 1,2020 |
28.09.2020 |
Samsung A71 | SM-A715F | Android version: 10 Kernel version: 4.14.117-18912382 Build number: QP1A.190711.020.A715FXXU2ATG1 Android security patch level: 1 June 2020 |
21.09.2020 |
