All All - FARO Products
FaroArm FaroArm - All Models
Laser Line Probe Laser Line Probe - Prizm Laser Line Probe - FAROBlu HD/SD V6 Laser Line Probe - Edge HD V6 Laser Line Probe - Edge ES V5 Laser Line Probe - Edge V4 Laser Line Probe - V3 Laser Line Probe - V2 Laser Line Probe - V1
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
FaroArm Accessories
Serial FaroArms
Serial FaroArm
All Models
English
Power Supply Specifications for the FaroArm Serial Power Box
Below are some options of portable power that can be used with the Serial Box. The Serial Box is very robust and is capable of running off various power supplies.
Specifications for the power supply are as follows:
  • 100 - 240V
  • .5 - .263A
  • 50 - 60Hz
  • + 12VDC
  • 2.08 A Max
1.) The most recommended power supply would be a UPS (Uninterruptable Power Supply) which has battery backup.
2.) Battery operation is acceptable with a power inverter.
3.) Generators are fine, but they are noisy and expensive.
Warranty for the FaroArm will not be voided if used with the above portable power supplies.
The only caveat is that all portable power systems used must conform to the operating requirements as stated on our labels and in our operating manual of the FaroArm. Uses outside of these requirements will void the warranty.
Keywords: power supply, brick, serial arm, DSP box, volts, amps, gold, silver, bronze
