Language Quality HT MT AT NT
All All - FARO Products
FaroArm FaroArm - All Models
USB FaroArm USB FaroArm - All Models USB FaroArm - Quantum S USB FaroArm - Advantage USB FaroArm - Digital Template USB FaroArm - Edge USB FaroArm - Fusion USB FaroArm - Platinum USB FaroArm - Prime USB FaroArm - Quantum USB FaroArm - Titanium
Public Safety Public Safety - All Software Public Safety - FARO CAD Zone Fire Insurance Public Safety - FARO CAD Zone Crime Crash Public Safety - FARO CAD Zone CZ Point Cloud Public Safety - FARO CAD Zone First Look Pro Public Safety - FARO Zone 2D Public Safety - FARO Zone 3D Public Safety - FARO 360 Reality Public Safety - FARO 360 HD Public Safety - FARO 360 Blitz Public Safety - FARO 360 Genius
PointSense1 PointSense - All PointSense Suite PointSense - PointSense Basic PointSense - PointSense Pro PointSense - PointSense Building PointSense - PointSense Plant PointSense - PointSense Heritage PointSense - PointSense for Revit PointSense - TachyCAD Building PointSense - TachyCAD Archeology PointSense - TachyCAD Interior
PointSense2 PointSense - PhoToPlan Basic PointSense - PhoToPlan PointSense - PhoToPlan Pro PointSense - PhoToPlan Ultimate BIM CIM - DisToPlan BIM CIM - MonuMap BIM CIM - hylasFM BIM CIM - VirtuSurv
Factory Metrology Factory Metrology - All Software Factory Metrology - Visual Inspect App Factory Metrology - Visual Inspect CAD Translator Factory Metrology - RayTracer
Gage
All Models
Serial FaroArm
All Models
USB FaroArm
All Models
English
German
Italian
FARO Factory Service Initial Incoming Inspection Procedure
When an Arm is sent in for service, the Arm must go through an initial incoming inspection. FARO's ISO 17025 accreditation requires us to report the incoming condition of the instrument.  The data sheet you receive back with your Arm shows the recorded measurements from the initial inspection and whether that inspection has passed, failed or the unit is inoperative.  The inspection status is listed on the cover page of the packet you receive back with the Arm. Your arm will then be recalibrated and re-certified after it has completed any services required.
If the Arm has failed the initial inspection, it is impossible for us to quantify when and how it went out of specifications as we do not know when the problem occurred.  Depending on your required accuracy and the way you measure, the effect could be much lower than what we report since we rotate the Arm from left to right in order to maximize the error induced.  This is known as a Single Point Articulation Test or SPAT.  We check the Arm throughout its measuring volume. Many customers only use it in a limited portion of the volume, which can greatly reduce the uncertainty and error of the instrument.
If you are still concerned about your Arm’s accuracy when you receive it back form service, we recommend you recheck some material that was previously measured before the service.  Doing a pre/post-analysis can help you identify any effect in their former measurements.  We also recommend that you routinely use a gage block or some other artifact to do verifications on the equipment.
Inspection, FARO Arm, USB Arm, Platinum Arm, incoming inspection, faroarm, inspecting
