Language Quality HT MT AT NT
All All - FARO Products
FaroArm FaroArm - All Models
USB FaroArm USB FaroArm - All Models USB FaroArm - Quantum S USB FaroArm - Advantage USB FaroArm - Digital Template USB FaroArm - Edge USB FaroArm - Fusion USB FaroArm - Platinum USB FaroArm - Prime USB FaroArm - Quantum USB FaroArm - Titanium
Serial FaroArm USB FaroArm - Titanium Serial FaroArm - All Models Serial FaroArm - Bronze Serial FaroArm - Gold
Gage Serial FaroArm - Silver Gage - All Models Gage - Standard, Plus, Power
ScanArm or Laser Line Probe Gage - Bluetooth ScanArm or Laser Line Probe - All Models ScanArm or Laser Line Probe - Edge LLP V4
FaroArm Accessories ScanArm or Laser Line Probe - LLP V1 V2 V3 FaroArm Accessories - All FaroArm Models FaroArm Accessories - USB FaroArms FaroArm Accessories - Platinum FaroArm Accessories - Titanium FaroArm Accessories - Gage FaroArm Accessories - Serial FaroArms FaroArm Accessories - Gold Serial FaroArms FaroArm Accessories - Silver Serial FaroArms FaroArm Accessories - All LLP Models
Laser Tracker FaroArm Accessories - LLP V1 V2 V3 Laser Tracker - All Models Laser Tracker - Vantage S M E Laser Tracker - Vantage Laser Tracker - ION
Laser Tracker Accessories Laser Tracker - Si X Xi Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION
Imager Tracker Accessories - Si X Si
Laser Scanner 3D Imager - Cobalt Laser Scanner - All Models Laser Scanner - Focus S M E Laser Scanner - Focus3D
Laser Scanner Accessories Laser Scanner - Photon Laser Scanner Accessories - All Models Laser Scanner Accessories - Focus S M E Laser Scanner Accessories - Focus3D
Hand Held Scanner Laser Scanner Accessories - Photon
Laser Projector Hand Held Scanner - Freestyle
Imaging Laser Radar Laser Projector - Tracer
Computers Imaging Laser Radar - VectorRI
Software Computers - All Computers
CAM2 Software - All FARO Software CAM2 - Measure
SCENE CAM2 - SmartInspect SCENE - All SCENE Suite SCENE - Capture and Process SCENE - WebShare Cloud and WebShare 2Go
Legacy Software SCENE - WebShare Server and Webshare 2Go Legacy Software - CAM2 Gage Legacy Software - Gage Software
Public Safety Legacy Software - Insight Public Safety - All Software Public Safety - FARO CAD Zone Fire Insurance Public Safety - FARO CAD Zone Crime Crash Public Safety - FARO CAD Zone CZ Point Cloud Public Safety - FARO CAD Zone First Look Pro Public Safety - FARO Zone 2D Public Safety - FARO Zone 3D Public Safety - FARO 360 Reality Public Safety - FARO 360 HD Public Safety - FARO 360 Blitz
PointSense1 Public Safety - FARO 360 Genius PointSense - All PointSense Suite PointSense - PointSense Basic PointSense - PointSense Pro PointSense - PointSense Building PointSense - PointSense Plant PointSense - PointSense Heritage PointSense - PointSense for Revit PointSense - TachyCAD Building PointSense - TachyCAD Archeology PointSense - TachyCAD Interior
PointSense2 PointSense - PhoToPlan Basic PointSense - PhoToPlan PointSense - PhoToPlan Pro PointSense - PhoToPlan Ultimate BIM CIM - DisToPlan BIM CIM - MonuMap BIM CIM - hylasFM BIM CIM - VirtuSurv
Factory Metrology Factory Metrology - All Software Factory Metrology - Visual Inspect App Factory Metrology - Visual Inspect CAD Translator Factory Metrology - RayTracer
FaroArm
All Models
All Models
English
Japanese
Issues That Can Degrade Accuracy with the FaroArm
Below are some issues issues that can degrade Accuracy while measuring with the FaroArms:
1-Mounting:
  • Do not mount to any type of wooden surface or do not mount to optical cables (as Vibraplanes), because the steel sheet on top of the tables is thin and deflects.
  • Folding tripods using the stabilizing struts are unstable.
  • Heavy-duty stands with wheels down and pins up are unstable.
  • Part deformation due to excessive clamping force.
2-Compensation:
With Probes:
  • Measuring with Point Probes.
  • Measuring with chipped, loose or cracked ball probes.
  • Measuring with probe extensions. The extensions will deflect.
With the FARO Laser Line Probe:
  • Do not drag the probe over the FARO Compensation Plate during the plane measurement. Lift the probe in between points to avoid scratching the surface of the plate.
  • Poor probe compensation technique. Do not do short sweeps with the FARO Laser Line Probe during compensation.
  • Dirty lens. Make sure to clean the top and bottom lenses with the cloth from the FARO Laser Line
  • Probe Case. Dirt and grease on either lens can cause poor results.
3-Measurement Environment:
  • Measuring close to an end stop can induce unwanted stress.
  • Extending the arm out as far as it can go can cause unnecessary stress.
  • Or repositioning the device using the Move Device Position command.
  • Excessive vibration in the surrounding area can produce unwanted results.
  • Rapid changes in ambient temperature can cause errors in the arms automatic temperature compensation.
  • Measuring using poor techniques; minimum number of measured points per feature, moving while recording individual points and small coverage area.
Special Note: If the arm is mounted on granite table or cart, do not measure objects that are not mounted to the granite table or cart.
