Language Quality HT MT AT NT
All All - FARO Products
FaroArm FaroArm - All Models
USB FaroArm USB FaroArm - All Models USB FaroArm - Quantum S USB FaroArm - Advantage USB FaroArm - Digital Template USB FaroArm - Edge USB FaroArm - Fusion USB FaroArm - Platinum USB FaroArm - Prime USB FaroArm - Quantum USB FaroArm - Titanium
Public Safety Public Safety - All Software Public Safety - FARO CAD Zone Fire Insurance Public Safety - FARO CAD Zone Crime Crash Public Safety - FARO CAD Zone CZ Point Cloud Public Safety - FARO CAD Zone First Look Pro Public Safety - FARO Zone 2D Public Safety - FARO Zone 3D Public Safety - FARO 360 Reality Public Safety - FARO 360 HD Public Safety - FARO 360 Blitz Public Safety - FARO 360 Genius
PointSense1 PointSense - All PointSense Suite PointSense - PointSense Basic PointSense - PointSense Pro PointSense - PointSense Building PointSense - PointSense Plant PointSense - PointSense Heritage PointSense - PointSense for Revit PointSense - TachyCAD Building PointSense - TachyCAD Archeology PointSense - TachyCAD Interior
PointSense2 PointSense - PhoToPlan Basic PointSense - PhoToPlan PointSense - PhoToPlan Pro PointSense - PhoToPlan Ultimate BIM CIM - DisToPlan BIM CIM - MonuMap BIM CIM - hylasFM BIM CIM - VirtuSurv
Factory Metrology Factory Metrology - All Software Factory Metrology - Visual Inspect App Factory Metrology - Visual Inspect CAD Translator Factory Metrology - RayTracer
FaroArm Accessories
All FaroArm Models
Serial FaroArm
All Models
English
Use and Handling Information for the Standard Serial FaroArm Probes
The recipe that we recommend for probe calibration is the 5-5-5-4-4-4 method. (27 points Total).
Half of the points are taken tangentially (with the probe pointing back towards the base of the arm), and half of the points are taken normally (with the probe pointing towards the center of the sphere). Also, half of the points are taken on one side of the long tube of the arm, and the other half are taken on the other side. You will periodically flip between positions. Basically, the recipe is as follows:
· 5 Tangential Around the Ball.
· Flip
· 5 Normal, East to West
· Flip
· 4 Normal, East to West
· 4 Normal, North to South
· Flip
This recipe should be followed for certain FaroArms listed below:
Bronze Series, Silver Series, Gold Series, Bronze (Millennium) Series, Sterling Series
· Device(s)
· Probes
· Select probe type
· Select a method of calibration
· Calibrate the probe (Follow instructions in the overview).
Caliper 3D for Windows
· Settings
· Select the probe type
· Click on the button called Calibrate
Handling/Storage/Warranty
When using the standard probes, be sure not to apply excessive pressure on the tips. This may damage the shaft or ball on the end of the probe and may not be covered under the warranty plan. When the probe is not in use, disconnect it from the FAROArm and store in the case in order to reduce any potential damage. Should any damage occur due to neglect of proper storage or misuse, this will not be covered under the warranty plan. Please refer to your Handbook or contact Customer Support directly regarding details of the warranty plan for your probes or other products. Probes are considered to be a consumable item and if worn because of use new probes should be purchased.
Keywords: serial arm, faroarm, probes, probe
