Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Change Startup Language of the FaroArm Manager
  1. Browse to: C:\Program Files (x86)\Common Files\FARO Shared.
  2. Locate the file FaroArm.Manager.exe, right click on it and select Create Shortcut, then drag the newly created shortcut to the desktop.
  3. Right click on the new desktop shortcut and select Properties.
  4. Under the Shortcut tab, click into the Target box.
    After "C:\Program Files (x86)\Common Files\FARO Shared\FaroArm.Manager.exe"
    ADD: [space]-culture:XXXX (where XXXX is the language code from the table below).
    For example, if you wanted to change the startup language to Japanese, you'd input:
    "C:\Program Files (x86)\Common Files\FARO Shared\FaroArm.Manager.exe" -culture:JA
    Language Code Language Code
    Chinese ZH-CN Polish PL
    English EN Portuguese PT
    French FR Russian RU
    German DE Spanish ES
    Italian IT Turkish TR
    Japanese JA
  5. In this example, Japanese (JA) is desired, so the text in the target box should read "C:\Program Files (x86)\Common Files\FARO Shared\FaroArm.Manager.exe" -culture:JA.
