LED Status for the Edge FaroArm
After applying power to the Edge, the Handle
LED is Solid Yellow while an internal startup
check runs. After this is complete, the LED
indicates the following:
• Flashing Blue - if the Edge successfully
communicates with the computer, and the
encoders are not referenced.
• Solid Blue - if the Edge successfully
encoders are referenced.
• Solid Green - if the Edge successfully
encoders are referenced - Renishaw Probe
only.
• Solid Red - if there is an error in the Edge.
If the LED lights on the Edge stay a solid color other than Blue, then there is an issue.
Red means a software issue.
Yellow means there is a possible pinched wire or defective board.
