FARO Zone FARO Zone - 2D FARO Zone 3D - 2018 FARO Zone 3D - 2019
SCENE SCENE - 2019
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Design ScanArm 2.5C
Design ScanArm 2.0
Design ScanArm
Forensic ScanArm
Gage
Bluetooth
Plus
Standard
Power
Serial FaroArm
Bronze
Gold
Silver
Mounting Orientation Requirements for the FaroArm
The FAROArm is portable and can be mounted in a variety of environments.  The counterbalance by the tension spring generates torque at the base of the FaroArm to allow easy movement of the arm.  The arm is not designed to be mounted on sideways on a wall or upside down.  This will affect accuracy and cause added stress to the arm.  Therefore the arm must me mounted in an upright position.
The only exception to this is some legacy model arms that were specially designed to be mounted upside down.  These are referred to as Inverted Arms.
See Also
Keywords
magmount, magnetic mount, magnet, magnetic
