As-Built As-Built - Revit As-Built - AutoCAD VirtuSurv - VirtuSurv 2018 As‑Built - Modeler
SCENE SCENE - 2019
Design ScanArm 2.5C
Design ScanArm 2.0
Design ScanArm
Forensic ScanArm
Firmware Download for the Laser Line Probe (LLP)
FARO LLP Icon
Quick Steps
Before you download and install the latest Laser Line Probe (LLP) firmware, make sure you have already downloaded and installed the latest FaroArm® driver and firmware for your FaroArm, ScanArm®, or Design ScanArm model. Refer to the See Also links.
Here is all you have to do. Click links to see details.
  1. Check the installed LLP firmware version and compare it to the latest version number found in the table in step 2.
  2. Click one of these links to download the firmware for your LLP model. If you are using the FAROBlu™ HD/SD, or the HD, and the version number is earlier than 650.8, contact FARO Support to send your LLP in to a FARO service center to upgrade the firmware.
    Release Date LLP Model Version Number Download Installation Instructions
    Aug 2018 Prizm 703.5  Download  Click Here
    Aug 2017 FAROBlu HD/SD (V6) 650.8 Contact FARO Support N/A
    Sep 2014 HD (V6) 650.8 Contact FARO Support N/A
    Sep 2013 ES (V5) 530  Download  Click Here
    Apr 2011 LLP (V4) 444  Download  Click Here
  3. For the LLP ES (V5) or LLP (V4), install the latest firmware.
    CAUTION: The firmware for the LLP and  LLP ES are not compatible with each other. Please make sure that you download the correct one.
  4. Confirm that the version of the firmware has changed to the latest version.
The LLP on your FaroArm works best when it uses the latest LLP firmware. Upgraded firmware includes bug fixes and features that make it easier to get your job done quickly. This article shows you how to upgrade your LLP firmware to latest version.
You can upgrade the firmware for the ES or LLP yourself. Just download the firmware and follow the instructions in this article. But, if you are using an FAROBlu HD or HD, you must contact FARO Support to send your LLP or Design ScanArm in to a service center so a technician can upgrade the firmware for you. You cannot do this yourself.
If you sent your LLP, ScanArm, or Design ScanArm to a service center after the firmware release date for your LLP model mentioned in the table above, the service center installed the latest firmware for you.
Prepare
Time to Complete
20 minutes
Skills Needed
  • General computer skills
Prerequisites
  • Internet connection
  • Computer you use with the FaroArm and LLP, ScanArm, or Design ScanArm
  • Latest firmware already installed.
Production Status
This table shows you which LLP models are currently in production and which are considered to be in Legacy status. FARO supports Legacy hardware for the length of time stated in your license agreement. If you have a legacy LLP and would like to learn about the ease-of-use features of the latest products, click here.
Production Status LLP Models
In Production Now Prizm
Blu HD/SD (V6)
HD (V6)
Legacy
Discontinue Date: Sep 2017 ES (V5)
Discontinue Date: Dec 2013 LLP (V4)
Discontinue Date: Sep 2017 V3
Discontinue Date: Jun 2011 V2
Discontinue Date: Apr 2005 V1
Check LLP Firmware Version
There are several ways to check the LLP firmware version depending on what software you use. The most common way is to use the FaroArm Manager, but you can also check the LLP firmware using CAM2 2018 or later and Measure 10.
FaroArm Manager
If you have installed the FaroArm driver version 6.x.x.x or later, you have access to the FaroArm Manager. This tool is installed with the driver on all computers you use  with your FaroArm. The FaroArm Manager enables you to quickly change FaroArm and LLP settings without opening other software.
  1. Connect your FaroArm with attached LLP to the computer using the USB cable.
  2. Turn on the computer and the FaroArm. Make sure that all applications are closed and nothing is communicating with the FaroArm and LLP.
  3. From the Microsoft Windows Start icon, click All Apps or All Programs FARO FaroArm Manager. The FaroArm Manager Home panel appears.
  4. In the Probes group, click Probe Management. All connected probes appear in the Probe Management panel.
  5. Look for the tile for the LLP connected to this FaroArm. Click on the green Connect icon in the upper-right corner to update the information.
  6. Click on the Edit pencil icon in the lower-left corner. The details for this LLP appear.
  7. Compare the Firmware Version number to that in the Quick Steps table.
  8. If the firmware is not the latest, write down this number so that you can verify that it has changed after you install the latest firmware.
CAM2 2018 and Later
  3. Open CAM2 20YY.
  4. From the ribbon, click Home > Device Center. The Device Center panel appears.
  5. Click on the FaroArm with the LLP attached. The Device Information panel appears.
  6. Click on Manage. In the All Probes group, look for the tile for the LLP connected to this FaroArm. Click on the green Connect icon in the upper-right corner to update the information.
  7. Click on the Edit pencil icon in the lower-left corner. The details for this LLP appear.
    If you are using a FaroArm driver 6.x.x.x or later, this is what you see.
    If you are using a FaroArm driver 5.8.5.2 or earlier, this is what you see.
    CAM2 M10 LLP Control Panel
  8. Compare the Firmware Version number to that in the Quick Steps table.
  9. If the firmware is not the latest, write down this number so that you can verify that it has changed after you install the latest firmware.
  3. Open Measure 10.
  4. From the main menu, click Devices > Device Control Panel (in some versions called Hardware Configuration). The Device Control Panel appears.
    CAM2 M10 Device Control Panel
  5. Click Measurement Mode Settings. The Mode Settings window appears.
    CAM2 M10 Mode Settings Window
  6. Click Settings. The Laser Line Probe Control Panel appears.
  7. In the Information section, compare the Firmware Version number in the LLP Control Panel to that in the Quick Steps table.
  8. If your firmware is not the latest, write down this number so that you can verify that it has changed after you install the latest firmware.
Installing Firmware for the Prizm LLP
  1. Click here to download the latest firmware for your LLP model.
  2. Ensure no software is actively communicating to the FaroArm and that the LLP is physically connected/installed.
  3. Extract the firmware .zip file to an empty folder.
  4. From the extracted files, run the Prizm_Load_FW_###_#.exe file. The update process should take approximately a minute. NOTE: If the process fails, close the software and attempt the install again. DO NOT turn off the power to the FaroArm/LLP until there is a successful update.
  5. When the process is finished, it will automatically re-boot the LLP. Close the update console software and the LLP will be ready for use.
Installing Firmware for the ES(V5) and LLP(V4)
  2. Extract the firmware .zip file to an empty folder.
  3. Open the folder and execute the UsbFlashLLP_V#_Firmware###.exe file.
Confirm the LLP Firmware Version Has Changed
  1. Repeat the steps in the appropriate Check Firmware Version section. Confirm that it has changed to the latest version number.
Your firmware has been updated and you can use your LLP.
See Also
Keywords
reinstalling, reinstall, re-install, updating, update, LLP driver, Laser Line Probe driver, laser probe, scanning, scanner, update, V4, V5, V6, version four, version five, version six, dsa, quantum s, quantum m
