All All - FARO Products
FaroArm FaroArm - All Models
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Scanner 3D Laser Scanner - Focus S 3D Laser Scanner - Focus M 3D Laser Scanner - Focus E 3D Laser Scanner - Focus3D 3D Laser Scanner - Focus3D X 3D Laser Scanner - Focus3D X HDR 3D Laser Scanner - Focus3D S 3D Laser Scanner - Photon
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
FaroArm
All Models
All Models
English
Japanese
Issues That Can Degrade Accuracy with the FaroArm
Below are some issues issues that can degrade accuracy while measuring with the FaroArm:
Mounting
  • Do not mount to any type of wooden surface or do not mount to optical cables (as Vibraplanes), because the steel sheet on top of the tables is thin and deflects.
  • Folding tripods using the stabilizing struts are unstable.
  • Heavy-duty stands with wheels down and pins up are unstable.
  • Part deformation due to excessive clamping force.
Compensation
With Probes
  • Measuring with Point Probes.
  • Measuring with chipped, loose or cracked ball probes.
  • Measuring with probe extensions. The extensions will deflect.
With the Laser Line Probe
  • Do not drag the probe over the FARO Compensation Plate during the plane measurement. Lift the probe in between points to avoid scratching the surface of the plate.
  • Poor probe compensation technique. Do not do short sweeps with the FARO Laser Line Probe during compensation.
  • Dirty lens. Make sure to clean the top and bottom lenses with the cloth from the FARO Laser Line
  • Probe Case. Dirt and grease on either lens can cause poor results.
Measurement Environment
  • Measuring close to an end stop can induce unwanted stress.
  • Extending the arm out as far as it can go can cause unnecessary stress.
  • Or repositioning the device using the Move Device Position command.
  • Excessive vibration in the surrounding area can produce unwanted results.
  • Rapid changes in ambient temperature can cause errors in the arms automatic temperature compensation.
  • Measuring using poor techniques; minimum number of measured points per feature, moving while recording individual points and small coverage area.
Special Note: If the arm is mounted on granite table or cart, do not measure objects that are not mounted to the granite table or cart.
