Disabling Wireless or Bluetooth on the Edge FaroArm
WiFi and Bluetooth can be turned off via the settings in the touch screen of the FARO® Edge Arm.
Note: The FARO Edge Arm can also be built without signal emitting chips. This feature must be specially ordered at the time of purchase. Click here for more information.
Disable WiFi
- From the MAIN menu on the Edge touch screen, press SETTINGS.
- From the SETTINGS menu, press CONNECTION.
- Make sure the WiFi radial button is unchecked to disable WiFi.
Disable Bluetooth
- Make sure the Bluetooth radial button is unchecked to disable WiFi.
Keywords
wifi, wireless, ethernet, Edge connection, government services. wi-fi, volatility
