CAM2 CAM2 - 2021
Exporting a SPAT Test from the Edge FaroArm
After a SPAT test is executed,
  • Plug in an SD card or USB drive into the Edge screen.
  • From the main screen, go to Files > Save Report.
  • Name the file and add a unique serial number.
  • Select the picture of the device you want to export the information to (SD card or USB drive). This will save the SPAT report to the desired device. NOTE: You should see the words "Saved" on the screen.
To view the report, explore the contents of the SD card or USB drive and look for a text file with the title <name>_<serial>.txt. The latest SPAT test will be the last one in the file (assuming there are multiple SPAT results listed).
spat, edge, export, review, report
