Factory Service Tests and Calibration Guidelines
When you send in your FaroArm or FARO Gage for factory service, these tests are performed as indicated by the ASME B89.4.22 guidelines.
- Effective Diameter Test
- Single Point Accuracy Test
- Volumetric Performance Test are performed.
See the link below for a sample report with details.
Click here to download: Quantum Calibration Report
See Also
- What are the steps in the 15-point check that is part of the FaroArm or FARO Gage factory service
- FARO Factory Service, Repair, and Certification Workflow
- FaroArm Compensation and Calibration
- What is the difference between the Standard, Premium, and Premium Plus Warranty Plans for FARO devices
calibration, process, report, calibrate, calibrating, arm, certification
