CAM2 CAM2 - 2021
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Design ScanArm 2.0
Design ScanArm 2.5C
FaroArm Manager Introduction and General Instructions
The FaroArm® Manager is an application installed with the USB FaroArm driver on your PC. This application is a workflow efficiency tool that enables you to connect to a FaroArm, perform calibration or compensation, configure settings, perform diagnostics, and check the firmware version number.
Using the FaroArm Manager
  1. From the Microsoft Windows Start icon, click All Apps or All Programs FARO FaroArm Manager. The FaroArm Manager main window appears.
  2. Use the links in the panels to navigate to do what you want.
    For additional documentation, download the Quantum User Manual.
  3. To return to the main window, click the arrow icon FaroArmManagerBackIcon.PNG in the upper-left corner under the FARO logo.
  4. To exit, click the X icon  FaroArmManagerCloseX.PNG in the upper-right corner.
Troubleshooting
With some installations (typically with heavy Windows/IT restrictions), probe data retrieval may be problematic. If you are experiencing these types of issues, running the Device Center application as an administrator can often be a solution.
  1. Navigate to the folder: “C:\Program Files\FARO Technologies\Device Center\Device Manager”
  2. Locate the application “FARO.DeviceCenter.exe”. Right click on the filename and chose Properties.
  3. On the Compatibility tab, check the “Run this program as an administrator” box.
  4. Click Apply and then OK.
See Also
configuration tool, calibration tool, compensation tool, configuration utility, calibration utility, compensation utility
