SCENE SCENE - 2019
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Design ScanArm 2.5C
Design ScanArm 2.0
Design ScanArm
Forensic ScanArm
Gage
Bluetooth
Plus
Standard
Power
Serial FaroArm
Bronze
Gold
Silver
Granite Work Cart FAQs
The Granite Work Cart, part number ACCS0164, is a convenient work center for the FaroArm® or FARO® Gage operator. The cart includes a printer and provides convenient storage spaces for your computer, monitor, tools, probes, and extension cords (all sold separately).
Country of Origin
Made in Taiwan
Weight
800 lbs, 362.874 kg
Weight Capacity
Hold weights that do not exceed 400 lbs, roughly 180 kg.
Granite Top
Topped with grade A granite, the flatness of the granite is not certified.
Threaded Inserts
Across the granite top there are threaded inserts that accept tooling hardware threaded rods and other tooling to hold your part. The thread sizes for the inserts are 3/8-16 UNC-2B for the field or circled thread sizes, and 10-32 for the 3½ in, 88.9 mm, ring mount pattern. You can remove the 3½ in, 88.9 mm, ring to use the six threaded inserts. There are also threaded inserts on the side of the cart, the thread size for these inserts is M20.
WARNING: To avoid cracking the granite top, DO NOT tighten fasteners in the threaded inserts beyond 50 in/lbs (6 N/m).
To download the metric dimensions of the currently shipping cart, granite top, and mounting ring, click these links.
To download the imperial dimensions for an earlier version of the cart granite top, click here.
Keywords
thread holes, granite cart, bolt holes, dimensions, cart dimensions, granite cart dimensions, shop cart
