LED Status for the Edge FaroArm
This article guides you through the multiple LED Status for the Edge FaroArm.
Handle LED
After applying power to the Edge, the Handle LED is Solid Yellow while an internal startup check runs. After this is complete, the LED indicates the following:
  • Flashing Blue - If the Edge successfully communicates with the computer, and the encoders are not referenced
  • Solid Blue - If the Edge successfully communicates with the computer, and the encoders are referenced
  • Solid Green - If the Edge successfully communicates with the computer, and the encoders are referenced (Renishaw Probe Only)
  • Solid Red - If there is an error in the Edge
Edge LED Lights
If the LED lights on the Edge stay a solid color other than Blue, then there is an issue.
  • Red means a software issue
  • Yellow means there is a possible pinched wire or defective board
