Language Quality HT MT AT NT
All All - FARO Products
FaroArm FaroArm - All Models
USB FaroArm USB FaroArm - All Models USB FaroArm - Advantage USB FaroArm - Digital Template USB FaroArm - Edge USB FaroArm - Fusion USB FaroArm - Platinum USB FaroArm - Prime USB FaroArm - Quantum USB FaroArm - Titanium
Public Safety Public Safety - All CAD Zone Public Safety - All FARO 360
BIM CIM BIM CIM - All Software BIM CIM - PointSense Basic and Pro
Serial FaroArm
All Models
USB FaroArm
All Models
English
Measuring the Deflection of the FaroArm
You should mount the indicator as high as possible, but low enough so that the counterbalance or decelerator does not contact the indicator as it is spun around encoder 1 or the encoder at the base.
1) Mount the FaroArm on the surface.
2) Torque down the locking ring or all the hex bolts with the Allen key.
3) Tighten down the probe with a wrench over finger tight.
4) With the Faro Arm in it's rest position, mount the dial indicator so that it rests against the base of the arm.
5) Reset the dial indicator so that it reads zero.
6) Pull the arm off rest and move the arm around it's volume while reading the dial indicator.
7) Move the indicator to a new location (i.e. 45 or 90 degrees).
8) Repeat.
The dial indicator should show no movement while the arm is being moved around its volume.
Keywords: deflection, serial arm, accuracy, silver arm, gold arm, usb arm
