SCENE SCENE - 2019
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Design ScanArm 2.5C
Design ScanArm 2.0
Design ScanArm
Forensic ScanArm
Mounting Requirements and Instructions for the USB FaroArm
The counterbalance by the tension spring generates torque at the base of the FaroArm. So to achieve optimum machine accuracy, the mounting must meet certain requirements.
NOTE: The FaroArm must be mounted in a upright position. Do not mount the FaroArm in an inverted (upside down) or sideways position.
To Fasten the FaroArm:
  1. Attach the 3.5" threaded ring and surface mount plate to any stable location. Tighten all mounting bolts to 100-inch pounds.
  2. Place the FaroArm on top of the 3.5” threaded ring.
  3. Screw the threaded collar clamp onto the base of the FaroArm and the 3.5” threaded ring.
  4. Use the wrench to tighten the threaded collar clamp.
Please see the attached document for more information.
Click here to download: Mounting of FARO Arm
Keywords: mounting, faroarm, setup, accuracy
