CAM2 CAM2 - 2021
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Legacy Gage
Bluetooth
Plus
Standard
Power
Design ScanArm
Forensic ScanArm
SPAT Test Function Location in Verisurf Software
First you will need to make sure you have the latest USB Driver which you can download on our website. Versions 5.5.1.2 and higher will be the only versions that will contain the SPAT test function.
You can then follow the path below to access the SPAT test.
FARO USB ARM CONTROLS > OPTIONS > DIAGNOSTICS
There should be a Perform SPAT button there.
The report will be saved as an excel format.
verisurf, spat, single point accuracy
