Release Notes for FARO Stream
This article lists the Release Notes for each version of the FARO Stream App to date. The current version release notes are displayed at the top of the article. Previous revisions are contained in expanding sections below.
Navigating this article:
- Use the Table of Contents block in the upper right hand of this article to jump to a release.
- You can expand a version section by clicking the + button
- To search all versions, click the Expand All Versions button and then use the Ctrl+f search feature in your browser. Sections must be “expanded” to be searched.
FARO Stream 1.1.0 Release Notes - January 2023
FARO is pleased to announce the release of Stream version 1.1.0. We would like to thank customers who provided valuable product input. This release includes feature enhancements that are designed to increase productivity, mobility and ease-of-use.
IMPORTANT: Install Focus firmware 7.1.0 (or later) on your Focus Premium or Focus Core scanner before you use this version of Stream. The firmware can be downloaded from the FARO knowledge base or via the online firmware update option in the scanner.
New Features
- Support for the FARO Focus Core laser scanner, including licensing via Sphere.
- On-site compensation results can now be shared as a pdf report.
- Stream now indicates the scanning phase (e.g., "Inclinometer capturing").
- Scan base names can now be modified per cluster.
- Added new PanoCam options introduced with the FARO Focus firmware 7.1.0.
Improvements
- Point-cloud data is now optionally automatically downloaded.
- The scanner must now be explicitly selected. Previously, when multiple scanners were in the same network, Stream selected one scanner randomly.
- Sphere processing can now be triggered for projects that were uploaded but not processed during upload.
- Several usability improvements and bug fixes for the top view.
- Several usability improvements related to annotations.
- Reworked scanner detection and connectivity checks.
- Improved diagnostics related to registration failures.
Bug Fixes
- Several fixes related to cluster management.
- Fixed several crash situations.
Known Issues
- If a scan is assigned to another cluster before the scan is finished, the project synchronization mechanism will fail, so that on the scanner the scan will still be in the original cluster.
- Workaround: Wait to shift scans to other clusters until the scan is complete.
- In rare case the streaming of a scan can be interrupted.
- Workaround: Wait until the scan is finished and it will automatically reload after the scan is complete.
