CAM2 CAM2 - 2021
3D Laser Scanner
Focus Core
Focus Premium
Focus3D X
Focus3D X HDR
Focus3D S
Photon
Dimensions and Weight of FARO Tripods and Stands
In the following article you will find all the information on FARO® Tripods and Stands.
Current Products
Part Part Number Height Weight
Standard Carbon Fiber Tripod ACCSS8032
  • Fully folded for transport: 29'' (730mm)
  • 0 tubes extended (Minimum Height): 27'' (679mm)
  • 1 tube extended: 42'' (1079mm)
  • 2 tubes extended: 59'' (1489mm)
  • 3 tubes extended (Maximum Height): 76'' (1936mm)
5.7lbs (2.5kg) with Quick Release Mount
FaroArm and Tracker
Rolling Stand ACCS-STND-0013 (Formerly 15036 & IG-9) 44"-68.5" (1118mm - 1740mm) 185lbs (84kg)
Rolling Stand ACCS-STND-0011 (Formerly 15037 & IG-10) 31"-43" (787mm - 1092mm) 158lbs (72kg)
Rolling Stand ACCS-STND-0010 (Formerly 15038 & IG-18) 22.5"-27.5" (572mm - 699mm) n/a
Rolling Stand ACCS-STND-0012 (Formerly 15039 & IG-24) 38"-56.5" (965mm - 1435mm) 177lbs (81kg)
Note: The Max Base Width for all models is 32.5" (825.5mm). All dimensions are approximate.
Legacy
FaroArm and Tracker
Rolling Stand IG-9 43” to 67” (1092mm to 1701mm) n/a
Rolling Stand IG-10 28” to 42” (711mm - 1066mm) n/a
Rolling Stand IG-18 20” to 25” (508mm - 635mm) n/a
Rolling Stand IG-24 36” to 54” (914mm - 1371mm) n/a
FaroArm Portable Folding Tripod 15532 (This part replaces 14422)
  • Maximum Height - 41'' (1.0m)
  • Minimum Height - 31'' (0.7m)
  • Maximum Spread - 54'' (1.4m)
n/a
Laser Tracker Portable Folding Stand 15531
  • Maximum Height -50'' (1.3m)
  • Minimum Height - 29'' (0.7m)
n/a
Portable Folding Tripod ACCS0134 13''X14''X46'' (330mmX355mmX1168mm)
  • 32 lbs (15kg)
  • Shipping weight 70 lbs (32kg)
Portable Folding Tripod 11356 13''X14''X46'' (330mmX355mmX1168mm)
  • 32 lbs (15kg)
  • 32 lbs (15kg)
