All All - FARO Products
FaroArm FaroArm - All Models
ScanArm or Laser Line Probe ScanArm or Laser Line Probe - All Models ScanArm or Laser Line Probe - FAROBlu HD/SD V6 ScanArm or Laser Line Probe - ES V5 ScanArm or Laser Line Probe - Edge LLP V4 ScanArm or Laser Line Probe - LLP V1 V2 V3 ScanArm - Design ScanArm 2.0
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Scanner 3D Laser Scanner - Focus S 3D Laser Scanner - Focus M 3D Laser Scanner - Focus E 3D Laser Scanner - Focus3D 3D Laser Scanner - Focus3D X 3D Laser Scanner - Focus3D X HDR 3D Laser Scanner - Focus3D S 3D Laser Scanner - Photon
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
3D Laser Scanner
Focus3D S
Focus3D X
Focus3D X HDR
Chinese
English
French
German
Japanese
Portuguese
Spanish
Memory Cards Used With the FARO Laser Scanner and Formatting Instructions
Focus3D Icon
The memory card that came with your FARO® Laser Scanner is correctly formatted and can be used immediately with your scanner and SCENE. Any other memory card must be correctly formatted before you use it.
The scanner and SCENE can read data from SD, SDHC, or SDXC memory cards with a storage capacity of up to 64 GB. The speed of the memory card must be Class 6 or better, and its temperature range should be from -20° C (-4° F) to 85° C (185° F).
All memory cards used with the scanner and SCENE must be formatted as FAT 32 file systems regardless of their size or rating. Although there are many ways to format memory cards, the most reliable way is to use the scanner's Format function.
For information about using memory cards with the laser scanner, see the user manual for your model scanner. The See Also section has links to all the different scanner model user manuals. Once you have downloaded the manual for your scanner model, search for SD card
