All All - FARO Products
FaroArm FaroArm - All Models
Laser Scanner
English
German
Japanese
Performance Specifications for the Focus3D
Please find below an overview of the performance Specifications of the FARO Focus 3D
Ranging Unit
Unambiguity interval:   153.49m (503.58ft)
Range Focus3D 120/1:  0.6m - 120m indoor or outdoor with low ambient light and normal incidence to a 90% reflective surface
Range Focus3D 20: 0.6m - 20m at normal incidence on >10% matte reflective surface
Measurement speed:  122,000 / 244,000 / 488,000 / 976,000 points/sec
Ranging error2: ±2mm at 10m and 25m, each at 90% and 10% reflectivity
Ranging noise3 @10m @25m @10m - noise compressed4 @25m - noise compressed4
@ 10% refl. 1.2mm 2.20mm 0.6mm 1.1mm
@ 90% refl. 0.6mm 0.95mm 0.3mm 0.5mm
Color Unit
Resolution: Up to 70 megapixel color
Dynamic color feature: Automatic adaption of brightness
Deflection Unit
Vertical field of view (vertical/horizontal): 305° / 360°
Step size (vertical/horizontal): 0.009° (40,960 3D pixels on 360°) / 0.009° (40,960 3D pixels on 360°)
Max. vertical scan speed:   5,820rpm or 97Hz
Laser (Optical transmitter)
Laser power (cw Ø) 20mW (Laser class 3R)
Wavelength 905nm
Beam divergence Typical 0.19mrad (0.011°)
Beam diameter at exit 3.0mm, circular
Data handling and control
Data storage: SD, SDHC™, SDXC™; 32GB card included
Scanner control: Via touch-screen display
New WiFi(WLAN) access Remote control, Scan Visualization and download are possible on mobile devices with Flash®
Multi-Sensor
Dual axis compensator: Levels each scan with an accuracy of 0.015° and a range of ±5°
Height sensor: Detects the height relative to a fixed point via an electronic barometer and adds it to the scan
Compass: Electronic compass gives the scan an orientation. A calibration feature is included.
