CAM2 CAM2 - 2021
3D Laser Scanner
Focus Core
Focus Premium
Focus3D X
Focus3D X HDR
Focus3D S
Reference Target Placement for Automatically Registering Scans in SCENE
FARO® SCENE can automatically detect reference targets and register related scans when you place the targets within the suggested range for the FARO Focus Laser Scanner. This saves you a lot of work manually identifying targets and registering related scans.
Details
The correct target placement depends on the target type, the scan resolution setting, the size of the reference targets, and how close or far away you place targets relative to the scanner.
Note: Regardless of the target type or size, the distance between the scanner and the target should never be less than 1m.
  70 mm Sphere 140 mm Sphere 200 mm Sphere
  Maximum Distance
Resolution ft m ft m ft m
1/1 116 35 232 71 331 101
1/2 65 20 129 39 184 56
1/4 32 10 63 19 90 27
1/5 23 7 45 14 64 20
1/8 16 5 32 10 46 14
1/10 13 4 25 8 36 11
1/32 8 2 15 5 21 6
Markers and checkerboard targets, printed at default size, should be placed within 50 ft of a scanner using 1/4 resolution.
minimum, maximum, min, max, placing, visible
