All All - FARO Products
FaroArm FaroArm - All Models
ScanArm or Laser Line Probe ScanArm or Laser Line Probe - All Models ScanArm or Laser Line Probe - FAROBlu HD/SD V6 ScanArm or Laser Line Probe - ES V5 ScanArm or Laser Line Probe - Edge LLP V4 ScanArm or Laser Line Probe - LLP V1 V2 V3 ScanArm - Design ScanArm 2.0
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Scanner 3D Laser Scanner - Focus S 3D Laser Scanner - Focus M 3D Laser Scanner - Focus E 3D Laser Scanner - Focus3D 3D Laser Scanner - Focus3D X 3D Laser Scanner - Focus3D X HDR 3D Laser Scanner - Focus3D S 3D Laser Scanner - Photon
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
Chinese
English
French
German
Japanese
Portuguese
Spanish
Focus3D Panorama Tripod Quick Release Mount Installation
Focus3D X 30/130/330 Series Icon
Quick Steps
Here is all you have to do. Click a link to get details.
Video
In this 3-minute YouTube video tutorial, learn how to unpack and set up the FARO Focus3D Laser Scanner on the panorama tripod.
The FARO Focus3D Panorama Tripod Quick Release allows you to quickly mount and dismount the Focus3D Laser Scanner on your tripod. Using the steps in this article you should be able install the Panorama Tripod Quick Release on your tripod and start scanning.
Prepare
Time to Complete 10 minutes
Items Needed
  • Focus3D Panorama Tripod Quick Release package, FARO Part #: ACCSS6040, Manufacturer Part #: 100200
  • Laser Scanner Carbon Fiber Tripod, FARO Part #: ACCSS6005
Supported Hardware
  • Focus3D X30/1310/330
  • Focus3D S20/120
Back to top
Setup
  1. Verify you have these parts in your Panorama Tripod Quick Release package.
    1. 1 x Mount assembly (two black components and integrated precision washer with knob)
    2. 1 x Screw (UNC 3/8x2”)
    3. 4 x Hex Screws (M5x20)
    4. 1 x Hex key 4mm
    5. 1 x Hex key 5/16”
    6. Optional: 1 x Tribrach to 5/8” adapter
      User-added image
  2. Remove the scanner from the transport case and lay the scanner on its side on a flat surface.
    If you have a scanner transport cover, you can install the Tribrach adapter with the scanner inside the cover. Just lay the cover, with the scanner inside, on its side on a flat surface.
    User-added image  User-added image
  1. Place the upper scanner mounting ring on the bottom of the scanner mount so that the four screw holes are aligned. Make sure that the set screw hole is opposite the power inlet.
    User-added image
  1. Insert and tighten the four screws with the included hex wrench; do not over tighten.
    User-added image
  1. To install the lower tripod mounting ring, first remove the 5/8-inch screw from the tripod using reasonable torque.
    User-added image
  1. This allows you to remove the 5/8” thread that you will set aside.
    User-added image
  1. Re-attach the black piece (pictured above) to the tripod with the lower portion of the quick release. Insert the 5/8-inch screw and tighten until snug with the included hex wrench. Make sure that the numbers on the tripod mounting ring are right-side up.
  1. Once the tripod mounting ring is secure, place the scanner on the tripod.
    User-added image
  1. Tighten the set screw to secure the scanner mounting ring to the tripod mounting ring.
    User-added image
Next Steps
Once you have confirmed the Tribrach adapter is attached and secure on the tripod, you are ready to use the quick release with your tripod and Focus3D.
Troubleshooting
If you cannot remove the screw in steps 5 and 6, please do not apply excessive force as it may damage the tripod. Instead, contact FARO Support for instructions.
See Also
Tribrach adapter, setup, install, unpack, set up
