CAM2 CAM2 - 2021
3D Laser Scanner
Focus3D X
Focus3D X HDR
Focus3D S
Scan Localizer Wireless Setup with the Scan Localizer App in SCENE
 Scan Localizer Icon
To use the Scan Localizer, you must wirelessly connect it with the computer that runs the Scan Localizer App inside SCENE. These instructions assume that you have downloaded Scan Localizer User Manual,and have followed the assembly, configuration, and installation instructions for the Scan Localizer and Scan Localizer App. The instructions in this article augment the instructions in the manual, section 6.3, Connect Scan Localizer with the computer using a wireless LAN. Read that section and then follow the detailed instructions in this article.
Prepare
Time to Complete 60 minutes
Skills Needed
  • General computer skills
Prerequisites
Supported Hardware
  • Focus3D X30/130/330
  • Focus3D X130/330 HDR
Video
In this tutorial, a FARO Application Engineer introduces you to the Focus3D Scan Localizer. You will learn why you should use it, how to attach it to your Focus3D, how to connect it to your computer or tablet and FARO SCENE 6.0 using Wifi and the Scan Localizer App, and how to to a cloud-to-cloud registration with SCENE and the Scan Localizer.
Details
The Scan Localizer should already be connected to the Focus3D and be switched on.
  1. Look on the Scan Localizer to find the serial number and write it down. The serial number starts with LSL07 and is followed by 7 digits. This number becomes the name or SSID of the Scan Localizer wireless network.
  2. From the Windows Start menu, click Control Panel > Network and Sharing Center > Connect to a network. The Currently connected to panel appears with the serial number of the Scan Localizer in the Wireless Network Connections list. You may have to scroll if the list contains many wireless networks.
  3. Click on the network represented by the Scan Localizer serial number, then click Connect. You are prompted for a network key.
  4. Enter 0123456789 and press Enter.
  5. In the Currently connected to panel, Connected and green bars now appear next to the network represented by the Scan Localizer serial number.
  6. Follow the advice as stated in the manual to switch off the Proxy server.
  7. Continue with the manual, section 6.4, Scan Localizer App, to set the IP address for the Scan Localizer and Laser Scanner.
