FARO Zone FARO Zone - 2D FARO Zone 3D - 2018 FARO Zone 3D - 2019
SCENE SCENE - 2019
Laser Tracker
ION
Si
X
Xi
Bolt Hole Pattern on the Bottom of the Laser Tracker That Can Be Used Instead of the Mandrel
The bottom of the tracker has a bolt hole pattern that can be used to mount the tracker to a fixture or mount instead of using the mandrel.
For the Vantage Tracker, this bolt pattern consists of four (4) 0.25”-20 UNC-2B holes spaced equally apart at 90 degree intervals. The bolt pattern forms a circle diameter of 3.125”.
For the ION / X/ Xi and Si Trackers, this pattern consists of (8) 0.25"-20 UNC holes forming a diameter of 3.126". The 8 holes are spaced equally apart at 45 degree intervals.
Keywords: mandrel, laser tracker, bolt hole, 3 inch ring, pattern
