FARO Zone FARO Zone - 2D FARO Zone 3D - 2018 FARO Zone 3D - 2019 present4D - present4D
SCENE SCENE - 2019
Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
Dimensions and Mounting Instructions for the 1.5 Inch SMR Permanent Reference Mount - C-ACC-05430-000
The 1.5" SMR Permanent Reference Mount is designed for mounting a permanent reference to a surface to securely hold a 1.5" SMR. This mount is used for reference only and is not intended for critical offsets or concentricity.  It has a cover to keep dust and dirt out of it and has laser etched dimensions to identify the target holder for component management.
It can be permanently secured using 1/4" bolts, through two counter bored holes in the base. Two 15/64” guide holes can be used as drill guides for the placement of dowels. After drilling 15/64ths holes into the substrate, use 1/4" reamer and then insert dowels to permanently mount the nest in this location.
  • Mounting holes:  0.266" diameter, counterbored to 0.438" diameter.  0.250" deep placed on 1.750" centers
  • Doweling holes: 0.235" diameter through placed on 1.750" centers
See Also
Best Practices for Using Laser Tracker SMRs, Targets, and Tooling and the Impact on Measurements
laser tracker targets,SMR configurations, SMR properties, SMR Specification
