FARO Zone FARO Zone - 2D FARO Zone 3D - 2018 FARO Zone 3D - 2019
SCENE SCENE - 2019
Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
Reset Wired Ethernet Settings to Factory Default for the Vantage S & E Series Laser Tracker
Below are instructions for performing a “Hard Reset” on the Vantage S & E series laser trackers. This will reset Ethernet settings back to their factory default as follows:
  • IP Address: 128.128.128.100
  • Subnet Mask: 255.255.255.0
This reset procedure can be useful if the trackers Ethernet settings have been changed to use DHCP and there is no network available to connect to the tracker or the tracker is in an area where Wi-Fi is not allowed. It can also be used if the tracker’s IP address has been changed to something other than the default values and FARO Utilities is not installed on the computer allowing the Find Trackers function to be used.
If the Tracker is currently powered on:
  1. Push and hold the trackers power button for at least 30 seconds and then release. The tracker will power down on release of the power button.
  2. Wait approximately 10 seconds and press the power button once to turn the tracker back on.
    • The tracker will take approximately 1 minute to complete its boot up routine. The red lights around the tracker Zenith axis and the red light near the tracker aperture will stop blinking once complete.
  3. After the tracker has completed its boot up routine, the tracker wired IP address will be set to the factory default settings listed above.
If the Tracker is currently powered off:
  1. With the tracker power supply connected to the tracker and wall outlet, push and hold the trackers power button for at least 30 seconds and then release.
  2. After the tracker has completed its boot up routine, press the power button once to turn the tracker off.
  3. Wait approximately 10 seconds and press the power button once to turn the tracker back on.
  4. After the tracker has completed its boot up routine, the tracker wired IP address will be set to the factory default settings listed above.
Note:  These procedures can be used on Vantage S/E series trackers that have firmware 2.5.0.2 or higher installed, which would include all units that shipped new or were serviced after December 2017.
