All All - FARO Products
FaroArm FaroArm - All Models
Laser Tracker
All Models
USB FaroArm
All Models
Setup and Align the FaroArm TrackArm and Laser Tracker Using CAM2 Measure 10 or Polyworks
Laser Tracker Vantage IconFaroArm Edge Icon
The FARO TrackArm is the most flexible portable 3D measurement device available. With a range of 70 meters and a probe reach of up to 12 feet, this seamless combination of the FARO Laser Tracker and FaroArm simplifies getting even the most challenging measurements while providing metrology-grade accuracy.
Quick Steps
To use the TrackArm system, take a few minutes to set up and configure it.
  1. Set up the FaroArm with the special TrackArm SMR. The Laser Tracker Accessories Manual has the part number for the TrackArm kit that contains the SMR and accessories to work with it. Contact your global FARO Sales Agent to order the TrackArm kit.
  2. Connect the TrackArm, Tracker and FaroArm, to your computer and turn them on.
  3. Compensate the SMR.
  4. Define the position or alignment of the FaroArm relative to the Tracker.
When you complete step 4, you can review the Max, Min, and Mean Error, as well as the Std. Deviation results. If the results are acceptable, you are done. If not, repeat step 4.
Device Manager Define With TrackArm Results
The Laser Tracker Accessories Manual, FARO TrackArm chapter has complete step-by-step instructions to set up, configure, and position or align the TrackArm. To find these instructions, just download the Laser Tracker Accessories Manual, and search the PDF file for TrackArm.
The See Also section in this article contains links to theCAM2 Measure 10, FaroArm, and Tracker User Manuals, as well as the Tracker Accessories Manual if you need them.
The TrackArm settings in Polyworks and in CAM2 Measure 10 may give varying results when aligning the Tracker and FaroArm. The difference is that Polyworks uses a default scan point spacing of 1mm, whereas Measure 10 uses a default of 5mm. You may modify the Settings in the CAM2 Measure 10 Device Manager to be 1mm to optimize the correlation between Cam2 Measure and Polyworks.
Device Manager Define With TrackArm Settings
