Communication Issue Troubleshooting with the Serial FaroArm
This information will help with the setup of the communications port and interface with the FARO ARM under the computer operating system Windows 2000.
1. Non-serial box FARO ARMS are recommended settings:
- Baud rate (Bits per second): 38,400
- Data bits: 8
- Parity: None
- Stop bits: 1
- Flow control: None
2. Serial Box FARO ARMS recommending settings:
- Baud rate (Bits per second): 9,600 (Nothing over 38,400)
- Data bits: 8
- Parity: None
- Stop bits: 1
DOUBLE CHECK
- Check that no conflicts are cause by unauthorized software or hardware (palm pilots, digital cameras, scanners, zip drives, etc.)
- Check the cables and connectors for bent pins, secure connections, or damage.
- Check to make sure that the correct cables are being used.
See the following document:
06REF178-111.DOC - FAST FAXES Troubleshooting (Cable Pin Outs) - 06REF178-111.doc
Keywords: Can not connect to primary input device, Troubleshooting Communication arm, communication between the computer, serial arm, bronze arm, silver arm
