All All - FARO Products
FaroArm FaroArm - All Models
Laser Line Probe Laser Line Probe - Prizm Laser Line Probe - FAROBlu HD/SD V6 Laser Line Probe - Edge HD V6 Laser Line Probe - Edge ES V5 Laser Line Probe - Edge V4 Laser Line Probe - V3 Laser Line Probe - V2 Laser Line Probe - V1
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
FaroArm Accessories
All FaroArm Models
Serial FaroArm
All Models
English
Configuration Using a Renishaw Probe on the Serial FaroArm and the Soft Check Tool Manager
The Aux Port must first be activated using Caliper 3D to use a Renishaw probe when programs are executed through Soft Check Tool Manager. To activate the Aux Port, follow the steps below.
1. Open Caliper 3D
2. From the PROBE menu, select EDIT
3. Set the AUX PORT to active
4. Enter the probe diameter and select OK.
5. Reboot the arm.
***NOTE: The arm MUST be rebooted after the port is activated. Changing the setting activates the port for the next boot up rather than acting as an ON/OFF type switch
soft, check, renishaw, probe
