SCENE SCENE - 2019
Advantage
Digital Template
Fusion
Legacy Quantum
Platinum
Prime
Titanium
Gage
Bluetooth
Plus
Power
Standard
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Serial FaroArm
Bronze
Gold
Silver
English
Japanese
Issues That Can Degrade Accuracy with the FaroArm and Gage
Below are some issues issues that can degrade accuracy while measuring with the FaroArm:
Mounting
  • Do not mount to any type of wooden surface or do not mount to optical cables (as Vibraplanes), because the steel sheet on top of the tables is thin and deflects.
  • Folding tripods using the stabilizing struts are unstable.
  • Heavy-duty stands with wheels down and pins up are unstable.
  • Part deformation due to excessive clamping force.
Compensation
With Probes
  • Measuring with Point Probes.
  • Measuring with chipped, loose or cracked ball probes.
  • Measuring with probe extensions. The extensions will deflect.
With the Laser Line Probe
  • Do not drag the probe over the FARO Compensation Plate during the plane measurement. Lift the probe in between points to avoid scratching the surface of the plate.
  • Poor probe compensation technique. Do not do short sweeps with the FARO Laser Line Probe during compensation.
  • Dirty lens. Make sure to clean the top and bottom lenses with the cloth from the FARO Laser Line
  • Probe Case. Dirt and grease on either lens can cause poor results.
Measurement Environment
  • Measuring close to an end stop can induce unwanted stress.
  • Extending the arm out as far as it can go can cause unnecessary stress.
  • Or repositioning the device using the Move Device Position command.
  • Excessive vibration in the surrounding area can produce unwanted results.
  • Rapid changes in ambient temperature can cause errors in the arms automatic temperature compensation.
  • Measuring using poor techniques; minimum number of measured points per feature, moving while recording individual points and small coverage area.
Special Note: If the arm is mounted on granite table or cart, do not measure objects that are not mounted to the granite table or cart.
