All All - FARO Products
FaroArm FaroArm - All Models
Measure
FaroArm
All Models
English
Measuring Parts beyond the Working Volume of the FaroArm Using Leap Frog
When working with parts which may extend beyond the working volume of the FaroArm®, the Leapfrog technique is used. The Leapfrog technique involves realigning the arm to a second position using features (circle, spheres) which are common to position 1 and position 2.
  • Circles and Spheres are mounted on the part close to the extension of the arm.
Note: The more area given for the mounted spheres or circles given will provide more accurate information. If the arm is extended to its full length with little area; more error will be encountered.
Before a Leapfrog can be performed, the circles and spheres must be measured in position 1:
  1. From the Measure Menu, select Plane. Measure the plane on the top surface of the part. Accept the label of M_PLANE1.
  2. Measure at-least 3 circles or spheres attached to the part. If using circles; from the Measure Menu, select circle. At the Plane Select dialog box, select M_PLANE1. Measure the first circle. Accept the label of M_CIRCLE1.
  3. Repeat the previous step for measuring Circles 2 and Circle 3.
At this time, CAM2 has enough information to begin the leap frog process:
  1. From the Alignment Menu, select CAD to PART< Leap Frog. (Up to 10 features may be used for the Leap Frog. )
  2. Select M_CIRCLE1, M_CIRCLE2, M_CIRCLE3. You are now prompted to measure each circle again.
  3. It is now ok to re-orientate the FaroArm into position 2, to measure the more of the part.
  4. Re-measure the three circles again and make sure to measure the correct circles. You will also need to define a plane for each circle.
  5. Now there is a new relationship between FaroArm and the part
Note: It is important to be efficient in the positioning of the FaroArm in order to minimize the amount of times the leap frog function is used. There is a minimal loss of accuracy associated with each re-orientation of the FaroArm.
Keywords
Method,Methodsheet,Methodsheets,instruction,instructions,step by step instruction, steps, process,guide,application specific,Measuring Parts beyond the working volume of The Faro Arm, Leap Frog, Leapfrog,move device position
