All All - FARO Products
FaroArm FaroArm - All Models
Measure
FaroArm
All Models
Chinese
English
French
German
Italian
Japanese
Portuguese
Spanish
Single Point Articulation Test (SPAT) in CAM2 Measure
Edge Icon
Video
In this 6-minute YouTube video, watch a FARO trainer show you how to check that the FaroArm mount is stable before you do the SPAT test, and how to do the test to check the repeatability of the FaroArm's X,Y, and Z coordinates throughout its full range of motion. Do not have access to YouTube? Click here to download the video.
CAUTION: Depending when you last upgraded your FaroArm driver, you will get better results if you hold the probe tip at a 45-degree angle from vertical (instead of straight-up vertical) and to sweep the FaroArm by holding it by the upper tube (instead of the lower tube). Also, if you are using CAM2 Measure 10, access the SPAT test in by going to Devices > Device Control Panel > Probe Management > Single Point Articulation.
