PolyWorks Version Compatibility With the Edge ScanArm HD or Laser Line Probe HD
As of December 2014, Innovmetric recommends that you use PolyWorks 2014 IR6 or a later with the FARO Edge ScanArm HD or FARO Edge Laser Line Probe HD (LLP HD).
Innovmetric does not support earlier versions of PolyWorks with the ScanArm HD or LLP HD.
Check with Innovmetric if you have more questions.
laser scanner, compatibility, works best
