All All - FARO Products Hardware - All FARO Products
Laser Line Probe Laser Line Probe - Prizm Laser Line Probe - FAROBlu HD/SD V6 Laser Line Probe - Edge HD V6 Laser Line Probe - Edge ES V5 Laser Line Probe - Edge V4 Laser Line Probe - V3 Laser Line Probe - V2 Laser Line Probe - V1
Laser Projector Laser Projector - Tracer M Laser Projector - Tracer SI Scan Head - Digi-Cube
SCENE Ver SCENE - 2018 SCENE - 7.x SCENE - 6.x SCENE - 5.x SCENE - 4.x
Advantage
Digital Template
Fusion
Legacy Quantum
Platinum
Prime
Titanium
Gage
Bluetooth
Plus
Power
Standard
English
Japanese
Renishaw Probe Installation on the FaroArm
The Renishaw probe does not connect in the same manner as the standard probes. To connect the Renishaw probe, unscrew the standard probe and set it aside. You'll see a bronze set screw on the tip of the arm. (under the location where the standard probe was connected) Remove the brass set screw, and attach the Renishaw probe in it's place.
When finished use extreme caution when putting the set screw back in place. If tightened or screwed too far down it will damage the connect pin and could void warranty if improperly installed.
See below for PDF out of the FaroArm Accessories Manual
Click here to download: Renishaw Probe
renishaw, installation
