All All - FARO Products
FaroArm FaroArm - All Models
ScanArm or Laser Line Probe ScanArm or Laser Line Probe - All Models ScanArm or Laser Line Probe - FAROBlu HD/SD V6 ScanArm or Laser Line Probe - ES V5 ScanArm or Laser Line Probe - Edge LLP V4 ScanArm or Laser Line Probe - LLP V1 V2 V3 ScanArm - Design ScanArm 2.0
Laser Tracker Accessories Tracker Accessories - All Models Tracker Accessories - Vantage Tracker Accessories - ION Tracker Accessories - Si X Xi
Laser Scanner 3D Laser Scanner - Focus S 3D Laser Scanner - Focus M 3D Laser Scanner - Focus E 3D Laser Scanner - Focus3D 3D Laser Scanner - Focus3D X 3D Laser Scanner - Focus3D X HDR 3D Laser Scanner - Focus3D S 3D Laser Scanner - Photon
Laser Projector Laser Projector - Tracer Scan Head - Digi-Cube
USB FaroArm
All Models
Chinese
English
German
Japanese
Spanish
Configuring stress-stops and stress-stop warnings on the USB FaroArm
Please note:
This solution is only valid for USB driver older than 5.7.6.3.
5.7.6.3 removed the ability to change the stress stop settings manaully.
If you have enabled the stress-stops on your USB FaroArm and you see a constant stress-stop warning on screen, please go into Devices > Hardware Config and make sure that the stress stops are set to a maximum of .182. This is the maximum setting for the USB series. If it is .182, lower it a to sensitivity of of .162. Check if it helps. If it does not, lower it by increments of 0.10 until it resolves the issue. If it ever gets to the point that you have to keep lowering it to point you have to almost turn it off (~.92), then we may want to bring the arm in for evaluation as the sensor may not be working properly.
stress, stress stop, warning, warnings
