3D Laser Scanner
Adapter to Attach the Scan Localizer to the Focus S Laser Scanner
The FARO® Laser Scanner FocusS is fully compatible with the FARO® Scan Localizer. All you need is an adapter to connect the Scan Localizer to the Focus. To get the adapter, please contact your regional FARO Sales Representative and ask for part number ACCSS8016.
Details
  1. Connect the top of the adapter to the Laser Scanner using a socket head scrap screw HS-SBHCS-0.375-160.75 and a 3/16 inch hex key.
  1. Connect the bottom part of the adapter to the Scan Localizer using 4 M5x16 bolts and a 4mm hex key.
NOTE: The FARO® Laser Scanner Focus3D X, Focus3D S, or Focus3D do not require an adapter to connect to the Scan Localizer.
